2007 GT500 Intercooler Pump Relay Location?
14K views 6 replies 7 participants last post by  Goose17
Where is the Intercooler Pump Relay located on the 2007 GT500? Installing the AFCO HE and want to purge the air out of the system. Thanks.
#3 ·
On a 2007 it's in a trapezoid shaped plastic box on your passenger strut tower. In the box will be 3 or 4 relays depending on whether you have HIDs or not. The pump relay is the front left when facing it from the front of the car. When you pull the relay you will see a group of 3 slots and a group of 2 slots. Jumper the two slots to run the pump.
Steve
#7 ·
Welcome to the forum! Some of these fellas have moved on... this thread is 4-5 years old and now closed due to age.
