Trailer Escape Door & Ramp?
829 views 12 replies 7 participants last post by  OX1
Would like to hear from different owners on escape doors. Basically, the basic escape door, and make the ramp setup. Or would you get the "full" escape door down to, and into the wheelwell area (including removable wheelwell).
It appears even the least expensive trailer I could find with the "full door", is on average 10-15 grand more than a lower cost, basic escape door trailer. Probably a better trailer overall, but I don't need a top notch trailer.
That and the ramp idea would seem useful for possible work/inspection of car maybe during a track day. Not sure if it's really up high enough for that type of thing. But ramp deal also allows you to open door further inside (I'd guess), without opening any escape door (IE, it's pouring out, you just want to get something in or out of car, @ car show weekend, lets say)
Discussion starter · #5 ·
Thanks for the replies. My main reservation of doing the ramps is I eventually want to use this as a 'travel" trailer also ( I retire in about 11 months). Have reasonably nice living quarters up front, and keep our Escape in rear.
Drive to area to see the sites. Unload Escape and use it local, but have rest of rear section of trailer to "live" in. Like a temp dining set and/or temp bed setups. A ramp setup would really cramp that ability, unless ramp was removable (not impossible I guess).
Discussion starter · #13 ·
So this was the least expensive trailer I could find with a full escape door setup. It is not V nose and does not have "upgraded" axles. Even though it is alum and 1000 lbs lighter than steel (3250 vs 4200), I think I may bang up against it's 6700 ish load capacity, especially after building living 1/4's and packing in my "FULL" tool kit (IE, I currently bring a 110V full size 25 gallon compressor to track days :)). It's about $22K
The other option is spec my own. I get 14K torsion axles with hydraulic brakes, V nose, and some options that do not come on the first trailer. I especially like the look of a charcoal trailer with black out package (although the first trailer does have some options I would not get, spec-ing it out myself, like the white interior walls). This is most likely a "cheaper" made trailer than the first, I realize.
Would look like this, but be 28' with alum wheels
8.5x28 V Nose Tandem Axle Anvil Cargo Trailer$10085.00
Standard features:
• 5200lb USA Made Drop Leaf Spring Axle with Electric Brakes• Rear Ramp Door w/ Spring Assist & Extension Flap
• 6'6" Interior Height• .080 Polycore Exterior (Semi-screwed)
• 36" RV-Style Side Door w/ Flush Lock & Hold Open• 8" steel tube main rails
• 1.5" x 1" steel tube in walls and ceiling• 16" OC Floor & Wall Members
• 24" OC Roof Bows• 7-way round plug/ 2 5/16" coupler
• 24" Stoneguard on front• Plastic Side Vents
• 12V Dome light with switch• ST205 15" Radial Tires
• Silver Painted Wheels• Aluminum fenders w/lights
• 4 Floor D-rings• 3/4" plywood floor/undercoated
• Premium 3/8" plywood sidewalls• EZ Lube Hubs
• 2000 lb tongue jack w/ Sand Foot• Beavertail frame
• Galvalume roof
Selected Options:
AXLE UPGRADES
Upgrade to hydraulic brakes on 7000 lb. tandem torsion axles from tandem 5200 lb. leaf spring axles (qty 1)$1707
Electrical Options
Add 12 volt led dome light (each) (qty 1)$43
Exterior Color
Charcoal grey (.080) polycore exterior (qty 28)$0
Exterior Options
Blackout pckg: black trim, atp, fenders, handles & steel wheels (qty 1)$441
Extra Height
7'6" interior height (qty 28)$728
Frame Options
12" o/c floor crossmembers (26' & longer) (qty 1)$214
Recessed tire compartment (qty 1)$256
Upgrade to 6" main frame from 4" main frame (qty 28)$812
Interior
Therma cool ceiling liner (qty 28)$196
Interior Walls, Ceiling, and Flooring
Insulated ceiling (req ceiling liner) (qty 28)$336
Jacks, Couplers, and Stabilizer Jacks
Bogey wheels 6" long (pair) (qty 1)$242
Heavy duty rear drop down jacks (3000lb) (pair) (qty 1)$200
Roof Vents, Side Vents, and A/C's
Brace & wire for a/c (qty 1)$86
Side Doors, Ramp Doors, and Double Rear Doors
54" x 48" escape door with flushlock (qty 1)$434
Wheel Upgrades
Upgrade to mag wheels (tandem 7000# axles) (qty 1)$569
Windows
15" x 30" vertical window (qty 1)$207
Total of Options:$6471
Total Price:$16556.00
A deposit of $4139.00 is required for production. FOR CUSTOM TRAILERS: When selecting an electrical package, A/C units, water packages or other complex/expensive options, your deposit WILL be significantly more, up to 25%.
