I know where most have put the T, but wondering what T you used and what sized tube?
Thats a shockerI got the Shelby gauge kit during black Friday week, some small parts were missing, including the plastic t and the rubber connector from t to small vac line.
third autoparts store I went to had them:
https://www.dormanproducts.com/p-17841-47338.aspx
https://www.dormanproducts.com/p-5038-47403.aspx
might be what you're looking for?!.
No, it's pretty much the same thing although the MAP sensor is a little larger. I mounted the MAP sensor near the inner fender by the firewall and routed the wiring harness that plugs into the MAP sensor through the existing hole near the clutch master. I don't think heat is that big of an issue in the rear corners of the engine bay. The brake master and my remote clutch reservoir also blocks heat from the engine and the headers.AEM does it a little different with 1/8" line and a remote transducer, so the vaccuum tube doesn't have to run all the way to the gauge. Debating where to mount it as inside the car would probably make it last longer than in the engine bay. I'll be playing over the next few days to see what works best.
Can I borrow some? I am at 9-10 at 1000 rpm idle.I don't have stock cams, but after it warms up it's in the 14-15 inhg range. I would expect around 20 inhg on the 5.4s.
