1 - 18 of 18 Posts
My 2020 GT500 is a daily driver in Michigan winter.
Can't find winter or all season tires in factory size.
Searched every tire site.
Would appreciate any help or suggestions.
Reactions: pughde
Goose,
Michelin web-site says this tire will not fit my car.
Believe they are wrong as the sizes are compatible.
Thanks,
Going to my tire store to order.
2020 GT500 Rapid Red Base model
Yes, but should fit.
Thanks
Yes looks like it will:
MICHELIN Pilot Sport 4SMICHELINPILOT SPORT 4S
(430)
|Reviews (375)
Tire Rack Tested
MICHELIN Pilot Sport All Season 4MICHELINPILOT SPORT ALL SEASON 4
Tire Rack Projection
Tire Rack Tested
Qty:
4
12345678
Per Tire:$466.99
Free Shipping
Qty:
4
12345678
Per Tire:$306.99
Free Shipping
Set of 4: $1,867.96Set of 4: $1,227.96
Price After Mail-In Rebate: $1,797.96Price After Mail-In Rebate: $1,157.96
Add to CartAdd to Cart
As low as $117/mo with AffirmAs low as $77/mo with Affirm
Save for LaterSave for Later
Estimated Delivery DateHow soon can I get this?Thu, 10/29
Road Hazard ProtectionFree($180.92 value. Two-year coverage.)Free($118.92 value. Two-year coverage.)
Consumer Survey Stats
Tire Category Rank(of available tires in size)1 out of 33N/A
Total Miles Reported2,298,035N/A
Would You Recommend9.0N/A
Wet Performance9.2Excellent
Dry Performance9.6Excellent
Winter/Snow PerformanceN/AGood
Comfort Performance8.9Good
Treadwear Performance8.4Good
Tire Specifications
Basic Specifications
UTQG300 AA A540 AA A
Service Description(110Y)110Y
Country of OriginFRUS
Detailed Specifications
Load RangeXLXL
Eco FocusMichelin Total PerformanceMichelin Total Performance
StyleN/AN/A
Tire Weight33 lbs33 lbs
Maximum Load2,337 lbs2,337 lbs
Maximum Inflation Pressure50 psi50 psi
Tread Depth9.5/32"10/32"
Rim Width Range10.5-12.5"10.5-12.5"
Measuring Rim Width11"11"
Section Width12.6"12.4"
Tread Width11.1"11.3"
Overall Diameter28.7"28.7"
Revolutions per Mile726726
The bigger question, at least in my OCD brain, is why would you drive an 80k+ car in salt, sand and slop? But then your car, your rules.
Understood. People look at me rather oddly when I drive my POS car. Its a 09 Aveo with 146k on the clocks...as I have 2 jeeps, a pickup and the Mustang. As I said, my OCD makes me want to keep stuff clean, so things sit on tenders over the winter. Go figure...
It sucks that there are no snow/winters. Let me know how it goes and what size you get. I may have to get some.
207431
Any updates? How are these performing in cold temps?
Do you have cftp? Or base? If base, why did you choose two different sizes for front and rears?
Welcome to the forum Tyler! Do you have a 2020 GT500? You can click your upper right avatar/account settings and enter your car info in the Vehicle Details section. It then displays under your avatar.
Also, if you are up for introducing yourself and showing us your ride, you’ll find our new member area here:
Discussion Starter #16 (Edited)
Any issues from having taller tire out back than oem? Issues with sensors (traction control, abs, speed)?
Base, not Carbon Fiber.
No snow yet, but All Seasons are fine in cold.
Sizes are same as original, 315/20 rear & 305/20 front.
2000 Roush Mustang GT Vert
1,500 bucks will get you a winter beater with 4x4 around these parts! No mount and balance required.
I have to agree. Buy a winter vehicle. Spend $5k or $10k and you will save that much damage to your car. The winters where I live are nothing like Michigan winters and I have a 4x4 truck standing by. I have a job that I have to show up to 24/7. My daily driver has been literally froze to the ground and wouldn't move. If there is 5 to 7" of snow on the ground, driving is perilous if not impossible.
1 - 18 of 18 Posts
