I posted this in a different thread but want to start a thread about gears and ratios so that it will be easier to search for later!
stock tires 285/40/18 (tire height is 27 inches)
4.56 @ 65mph is 2324rpm with stock tires
4.10 @ 65mph is 2089rpm with stock tires
3.73 @ 65mph is 1901rpm with stock tires
3.31 @ 65mph is 1687rpm with stock tires
__________________________________
Now with 305/35/20 (tire height is 28.4 inches)
3.31 @ 65mph is 1604rpm
3.73 @ 65mph is 1809rpm
4.10 @ 65mph is 1986rpm
4.56 @ 65mph is 2209rpm
Top Speed @ 6000rpms in 6th gear
stock tires
4.56 = 167.9mph
4.10 = 186.7mph
3.73 = 205.1mph
3.31 = 231.1mph
now top speed with 20's
4.56 = 176.5mph
4.10 = 196.3mph
3.73 = 215.8mph
3.31 = 243.2mph
I used these calculator list in the previous post to come up with this info. The the calculators are correct why wouldn't you put 4.10's or maybe even 4.56's?
Face it driving down the highway with 4.10's @ 65mph @ less than 2100rpms is not bad and if you want to you can go almost 187mph in 6th gear (how often are you going to do that?) and if you put 20's on your rpm will lower because it is a taller tire. I think I will be putting 4.10's in eventually!
Here are the transmission gear ratios:
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
calculators use:
http://www.miata.net/garage/tirecalc.html
http://www.csgnetwork.com/multirpmtirecalc.html
http://huntergraham.com/twcc.htm
stock tires
4.56 = 167.9mph
4.10 = 186.7mph
3.73 = 205.1mph
3.31 = 231.1mph
4.56 = 176.5mph
4.10 = 196.3mph
3.73 = 215.8mph
3.31 = 243.2mph
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
calculators use:
