injectors not needed unless you plan to mod to achieve over about 750rwhp. If your is an 08, as your sig states, your current balancer is good for a TVS SC. The innovators west lower will net about 4 more lbs of boost. Need to consider what your ultimate performance level is you want. Many packages out there.Got the HE and DS. Do some change out injectors, and is a lower pulley needed?
1 piece aluminum dynotech is most folks preference. TB's again depends on your goal of achieved hp. Currently running bbk, but changing to monoblade. But there are new ones out, the CJ TB and MAF is only one. BBK and CJ require no new tune to install. Again, you need to research and decide what you want. Many options. But more hp also means getting it to the ground, so suspension, gearing are all factors to consider...I have the same question but I have the cooling covered. What is the next performance mod? Lower pulley? Throttle body? drive shaft? Where will see the biggest difference?
A good unit but not necessarily essential. Discharged temps with a TVS, 180* t-stat and the AFCO HX are comparable to the C&R units.+1...RevanRacing/C&R Radiator & HE are essential. Nothing else compares.
Pick the parts that will help you best attain your goals.Alright, now that stage 2 is being done, what other important changes need to be made other than new plugs and a re-tune?
true, to a degee, if your not going to beat on it road racing, or are in a lot of heavy city traffic. But if road racing, even infrequently, you'll want it...you'll be heat soaked and won't last....but again...depends on every persons own goals. JMO. Van's data speaks for itself...A good unit but not necessarily essential. Discharged temps with a TVS, 180* t-stat and the AFCO HX are comparable to the C&R units.
Not true. I was at the TrackGuys.com event at TWS just 2 weekends ago and no heat soak and no loss of power. Just my experience..But if road racing, even infrequently, you'll want it...you'll be heat soaked and won't last....
Not arguing the C&R setup's efficiency, just the argued necessity.Van's data speaks for itself...
