Anyone know what paint type and color Ford used on the undercarriage? I have a Kona Blue 2010 GT500 and the undercarriage is this greenish yellow color. I need to touch up some parts since I will be welding on the undercarriage.
I did a full “bottom restoration” on my 94 Cobra and learned a lot during the process. The bottom paint is often referred to as a “slop coat” if I recall correctly. It is the result of mixing all the leftover body color paint. There isn’t a paint code. I removed a piece and took it to a paint shop. They color matched it for me. Get a satin finish.The whole underneath carriage is painted or dipped in it and is this color except near the edges which have the Kona Blue fading into it.
View attachment 212489 View attachment 212490 View attachment 212491
Thanks!Its actually the color from e-coating the metal and isn't paint. Cant really be scraped off. SEM makes what they call E-Coat primer in a range of greenish hues thats pretty close:
Ez Coat™ | SEM Products
Ez Coat is a unique direct to metal coating that matches the color and gloss of factory primer and e-coat colors.www.semproducts.com
Let us know how well it matches please.Thanks!
I think the Olive Green will be the best match for my car. Their site says dark green but I don't think my color is dark green.
OMG Goose, when do you sleep?I did a full “bottom restoration” on my 94 Cobra and learned a lot during the process. The bottom paint is often referred to as a “slop coat” if I recall correctly. It is the result of mixing all the leftover body color paint. There isn’t a paint code. I removed a piece and took it to a paint shop. They color matched it for me. Get a satin finish.
You can see my paint work around the 10:20 mark:
Funny! 😆 I actually just woke up a bit ago from flying all night.OMG Goose, when do you sleep?
Just curious, your wife ever accuse you of being anal retentive?
That’s why I took a removable part off and hit-up a paint store to color match it.Update .... I tried Light Green, Olive Green and Dark Green (color SEM recommended) to try to match the underneath of my 2010 GT500. I read an earlier post from a few years ago and they said Olive Green was the best match. On mine I think the Dark Green SEM Ez Coat is a better match...not perfect but closer. None match the factory color exactly on my car.
Ken,Picture would help. A "greenish yellow" sounds like a zinc oxcide primer.. Nothing like that under my '08?
Thanks for the updateUpdate .... I tried Light Green, Olive Green and Dark Green (color SEM recommended) to try to match the underneath of my 2010 GT500. I read an earlier post from a few years ago and they said Olive Green was the best match. On mine I think the Dark Green SEM Ez Coat is a better match...not perfect but closer. None match the factory color exactly on my car.
Hey Bob, just spotted this.Ken,
Post some photos of your 08’. If I recall correctly, it is hit or miss what color the undercarriage is.
my GUESS is the slop color mix if from the old days, pre Fox body.. i have been under the impression that cars have been E Coated in a vat since the early 80's. i know the Mopars from the late 60's early 70's were E Coated dipped the lower 2' of the car. i have restored at least 30 E Body Mopars and have seen the primerline in the middle of the cowl first hand multiple times.Thanks for the info @thatsmrt2you
I haven’t witnessed it first hand like you. I do see quite a bit of reference to “slop mix” across the web. If these are in fact different, I guess it’s possible that “slop mix” and “e-coat” are both correct, but apply to different generations of Mustangs...? I’m not the expert here.
When I was restoring the bottom of my 94, I bought various paints to try and match the color... I couldn’t get a match. That’s when I researched Mustang bottom colors and came across the “slop mix” term. Getting color-matched paint was my solution that worked well.
"Puke green!" Lovely analogy, Uncle Bobby!No expert on this as I don’t typically look at a guy’s undercarriageSpeaking to the 07-09 cars, I’m not sure why some undercarriage are different than others. Mine is the puke green, I see some of that color in the engine compartment where there wasn’t enough paint applied, inside the fender/door gap, inside the deck lid, etc. For someone like me, seeing it in these areas is annoying. I would prefer to see these areas covered with plenty of body color. If I recall correctly, @RhinoRacing and @Robert M their cars have good solid body color in these areas.
