1 - 20 of 29 Posts
My engine is dusty and could use a bit of detailing, but I’m hesitant to use any of the cleaners that require rinsing or pressure washing for fear of electronics getting wet and causing problems. What do most of you use for under hood detailing?
I use Simple Green for the easier stuff and Goof Off Heavy Duty Remover for the more challenging grime... it’s powerful stuff!
Cleaner
2013 GT500 and 2020 GT500
What do you guys use on the black hoses?
Simple green to clean and Magestic Solutions Quick Details to shine!
I spray the entire engine with this stuff with the exception of the polished aluminum bits. It makes everything POP!
I use Adams In & Out spray
Unfortunately, asking what detail product people use is a lot like asking what oil people use. You’re going to get a lot of different answers, and most will work just fine.
'cause,
pressure washer doesn't affect you electrical connections?
If you're going to do that, it doesn't hurt to fire up the engine and let it get to operating temperature, so any remaining water evaporates. I just would not go crazy around the coil covers. That void between the cylinders can probably hold a gallon of water too, so no need to get crazy with it.
Discussion Starter #15
Last few times I tried to post pictures, I couldn’t get it to work. It’s not really dirty. Just a bit dusty. Only has 1400miles on it. Just like to see underhood as clean as outside and interior. I keep it garaged, under a cover and I guess I’m a clean freak.
I use Castrol Super Clean. Slightly warm engine. Do not spray on matt or polished aluminum as it will dull. let it soak for 10-15 minutes and wash off with hose spray. Start engine to dry. As it is still warm spray on Meguiars #40 Vinyl and Rubber cleaner, on plastic and hoses, then slam the hood. Check back later and it will look like new. Done it on many cars and no issue.
Pictures are real easy from a phone, tablet or computer. Use the right circled option to upload 1 pic. Use the left circled option to upload multiple pics.
I am using the right option to upload this screen shot from my iPad:
191867
2019 GT350R FPB
Swiffer for everyday dust maintenance is all I do.
For dirtier clean ups, Megs D101 in a 50/50 mix with decent microfiber towels.
You can get megs d101 on amazon cheap. It’s all purpose and works from interior cleaning to engine.
2014 GT500
I use a microfiber cloth and a paint brush with rubber tape covering the metal band around the bristles. All by hand and zero dressing. Just a nice, clean engine.
Sounds time consuming
1 - 20 of 29 Posts
