1 - 7 of 7 Posts
2021 Ford GT500
2021 GT500, I have noticed that I now have a strong gas smell in the garage after driving the GT500. Didn't happen when I first got it, but does now. Anyone else have this problem?
Moved your post here.
Haven’t had any issue like this. Get under the car and have a look.
You may want to pull it outside to be safe. The fumes are what ignites and if you have a typical set up, the pilot on your water heater or furnace will ruin your day. Like Goose said, I would take a peek to confirm a leak, but then pull her out and have towed to your dealer.
Is the weather changing? I notice mine has a fuel smell on occasion but I'm 99% sure it's coming out of the gas filler opening. It's most prevalent when the temps change - I stick my nose in the area of fuel door and can smell it. Had it happen with my truck, too.
2012 & 2021 GT500 strippers
With the wee gas tank, I overfilled mine on one of the early fill ups and smelled gas for while, but only a weak scent in the cabin. I had no smell when I opened he hood.
2014 GT500 PP
If you believe it is coming from the gas fill it may be the rubber gasket not fully sealing when cold. See if Ford offers a lockable plug for the fuel neck. That may seal it better.
Tom
1 - 7 of 7 Posts
