1 - 15 of 15 Posts
My stripe is lifting on the back of the trunk lid where it overlaps the piece under it. Should I make Ford fix it or is there a simple fix with an adhesive that someone knows of? I would just be gluing one stripe to the other - I just don't want to void the warranty.
I would try cleaning it with alcohol and a cotton ball, and use a blow dryer to LIGHTLY warm up and press down first.
Got it to stick down partially but its not perfect. Should I try an adhesive of some kind next?
I deal w/ many types of adhesives all day long, I'm not sure what I would try for vinyl to vinyl on an exterior piece...I'll have to think about that one.
Office Depot sells a very thin, clear, double sided tape. It's about 1/2 inch wide, so you'd have to trim it to fit. It might be a cheap method to try first, and it's undoable if you don't like the results.
1 - 15 of 15 Posts
