I made a small list of items that I wanted to do to right off the bat to my new-ish Shelby.
I ordered the following items:
Jacking rails -- Steeda 555 5212 Mustang Coupe Full-Length Jacking Rails (15-22)
IRS alignment kit -- Steeda 555 4438 Mustang IRS Subframe Alignment Kit (15-22)
IRS Brace -- Steeda 555 5754 Mustang Coupe Rear IRS Subframe Support Braces (15-22)
Install for all of these parts is easy and pretty straight forward. Install the alignment kit before the IRS brace to prevent you from installing the braces twice.
I installed the jack rails first by getting creative with my quick-jack and jack stands.
I then was able to loft the car back up and installed the bushings and IRS brace.
Be sure you double check the bushing orientation as there is a relief cut on one side for the bolts (the picture shows the difference)
Wrong way
Correct way
The rest of the install is easy using the instructions from Steeda below
This is the reason I did this, you can really see the difference one the bushing is inserted.
loosey goosey
good and snug
Wrong way
Correct way
loosey goosey
good and snug
