Shelby GT500 Backup LEDs
Here's a great way to upgrade your Shelby GT500's appearance and safety at night. These are great additions to any tail lights, and can be easily installed, plug-and-play. No resistors or anything needed. Perfect for GT500s equipped with backup cameras!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
The bulbs use an exact terminal and will fit as a replacement for stock incandescent All bulbs use less power and heat than the stock bulbs, and will last longer than your vehicle. Our LEDs use only the best components and are of the highest quality. The bulbs are designed for exceptional heat dispersion, and a diode is implanted to protect the LED from reverse polarity or voltage surge. The LED is wired for 12V operation, the kind found on all vehicles.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click Here 2007-2012 GT500
XP50 vs. Stock
Any questions, feel free to ask via email ([email protected]), Post, PM or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
Customer Submitted Photos:
Customer Reviews:
"What a significant difference in brightness. Sharp color and as bright as a flashlight. No question this car is backing up. Easy install and perfect fitment." (Posted on December 18, 2013)
"My stock lights were working fine BUT with my dark tinted windows I could barely see any backup lighting at all. After talking with Nick C. I went with Stage 2 on these backup bulbs. I'm VERY glad I did! They are BRIGHT and I can now see well when backing up.
Quality of the lights is fantastic! Solid well made product.
Being that they are so much larger than stock do take your time putting them in. A bit of a tight squeeze at the opening.
Highly Recommended!" (Posted on March 14, 2014)
"I ordered these for my mustang and i got stage 1. All I can say is they are really bright. The only way i would go stage 2 is if i had tint. I didn't have any problem installing them. I just had to tweak the contacts a little to get good connection. I am really glad i got them. They have a great white color to them. No one will ever not see me backing out of a parking spot at night.' (Posted on February 21, 2014)
