1 - 2 of 2 Posts
X3 Power Flash Handheld Programmer
Key Features:
• Latest Flash Technology
• Stores up to 3 Custom Tune Files
• Reads / Clears DTC Trouble Codes
• User Adjustable Features
• Monitor Popular External Sensors
• Most 2008 Models Supported
• Built-In High Speed Datalogging
User Adjustable Features:
• WOT Fuel Adjustment • Idle RPM
• Spark Adjustment • Transmission Shift Points
• Axle Ratio • Fuel Injector Size
• Tire Size - Rev / Mile • Air Intake Selection
• Cooling Fan Temps • Traction Control On / Off
• Rev / Speed Limiters • Two StepOn / Off RPM
* Not all adjustments available on all vehicles
Stores 3 Custom Tunes:
The NEW X3 stores up to 3 Custom Tune files which can be loaded by any of SCT’s Custom Tuning Dealers World Wide!
Large Backlit Screen:
With a HUGE Backlit display, the SCT X3 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source via the Dual Input Analog port.
Read / Clear DTC Codes:
Using the X3 Power Flash Device, you can now Read, Clear & Diagnose Trouble Codes without the expensive diagnostic fees charged by dealerships or your local garage.
$250
315-254-6602
Tim
1 - 2 of 2 Posts
