1 - 13 of 13 Posts
2010 GT500
Hi! Newby question ... what is the group opinion on Royal Purple tranny fluid?
Used it in my 2008 model, and it didn't make much difference. I think more people have better results using Amsoil (from what I've read in the past).
My experience was this. Changed out the trans fluid to Amsoil. Really didnt change much except for making cold shifting worse. Ran it for about 900 miles and switched it out for Mobil 1 synthetic atf. Way better cold shifting and smoother shifting all around. I am a Amsoil oil user in my engine also, so Im not hating on Amsoil.
Reactions: ihaterice
I also found royal purple to be no better than the original ford transmission fluid. And expensive , and a messy pain to flush out the purple.
Used it in my 2008 model, and it didn't make much difference. I think more people have better results using Amsoil (from what I've read in the past). CORRECTION BELOW .......
That's right ... now I remember .... it's Mobil 1 for the tranny and Amsoil for the engine ... :)
If I remember right, Mobil 1 is the only thing Tremec recommended...fresh fluid definitely feels nice.
I looked at all the product data sheets on most of these synthetic ATF fluids and Mobil 1 had the closest viscosity to Dextron III, which is what comes in them from Tremec. In this case thinner is better.
Reactions: JTB
There's a sticker right on the 6060's that indicates Dextron III
1 - 13 of 13 Posts
