Wanted to see if anyone has personally ported their vmp gen 3 supercharger. Or if anyone has to a similar blower. What were the results?
Thanks in advance
Thanks in advance
Isn’t the gen 3 TVS already capable of more power than a stock bottom end can handle on a 07-14? Are you going with a built motor?Wanted to see if anyone has personally ported their vmp gen 3 supercharger. Or if anyone has to a similar blower. What were the results?
Thanks in advance
VMP does recommend anything lowered than 2.8 pulley on pump. (I have 3.0 with a 10% lower so basically 2.8) and I am currently running a 67mm TB.What pulley? A 2.5 on a gen3 should get you close to your goal. I would think anyways. If you’ve got factory cats maybe the tune is a little rich safe to keep temps down but 750 on pump gas is definitely doable on the gen3 I see them pretty regular. There are just many variables locations, temp, heat soak due to inter cooler pump. Those numbers heatsoaked would be pretty close to 750 cooler day cooler temps. What throttle body are you using?
