Racing or just for the 'street' ??
Stainless Works headers | 2" x 3" headers |
Lethal Performance resonator delete | H-Pipe delete |
Nitto (front 305/35R20) | NT555 G2 |
Nitto (rear, 315/35R20) | NT555 RII |
Kong 108mm Throttle Body | 108 Billet |
Injector Dynamics | ID1300x |
NKG Iridium IX | LTR7IX-11 |
Palm Beach Motorsport | Heat Exchanger |
Whipple Superchargers | 1" - 1" Intercooler |
SPE | IC Manifold - Whipple |
SPE | Thermostat |
LP Griptec | 2.5" Pulley Kit |
Gates 8 Rib HD Belt | K080670HD |
SPE | Fuel Rail Kit |
Whipple Superchargers | Belt Tensironer |
Jokerz Performance | SC porting |
Gforce Performance | FOR10115A Axles |
SPE | Vertical Links |
Kelltrac | IRS Subframe Posi-Loc |
Palm Beach Motorsport | Tuning |
Street/strip (occasionally)Racing or just for the 'street' ??
The only thing on your list that I’ve done is the Kelltrac Posi-Loc mod:So I'm fixing to start upgrading my 21 and I have a list of mods I want to do to it. I would like to get some feedback on what I need now vs what can wait to be bought and installed later. I've been reading and it appears that the fuel rails could be added later, and the Gforce axles upgraded later. Anything else I'm missing or other suggestions?
Stainless Works headers 2" x 3" headers Lethal Performance resonator delete H-Pipe delete Nitto (front 305/35R20) NT555 G2 Nitto (rear, 315/35R20) NT555 RII Kong 108mm Throttle Body 108 Billet Injector Dynamics ID1300x NKG Iridium IX LTR7IX-11 Palm Beach Motorsport Heat Exchanger Whipple Superchargers 1" - 1" Intercooler SPE IC Manifold - Whipple SPE Thermostat LP Griptec 2.5" Pulley Kit Gates 8 Rib HD Belt K080670HD SPE Fuel Rail Kit Whipple Superchargers Belt Tensironer Jokerz Performance SC porting Gforce Performance FOR10115A Axles SPE Vertical Links Kelltrac IRS Subframe Posi-Loc Palm Beach Motorsport Tuning
Definitely do all those mods all at once, you don't want to be going back for a second time. Also the spark plugs at that time. Also something I have come across while modding these cars in regards to pulley size if you don't plan on going crazy chasing numbers. I'm currently running 2.7 clutched pulley and love it not using any after maker tensioner or auxiliary tensioner and get no belt slip or TONS of belt dust. I'm currently making 1000whp on pump e85. This is my second GT500 my first one I ran a 2.4,2.6,2.75 pulley always had issues with belt slip/belt dust unless you are looking to go 1100whp or up I would look into 2.7 clutched pulley. If you really want big power I would consider going with the Whipple. I also used the Whipple tensioner, spe auxiliary tensioner on the first build.I tend to do things that are part of the same systems. You mention fuel rails. While they're not completely necessary, if you intend to upgrade them, I'd do those along with the supercharger port, intercooler and injectors. Maybe I'm just lazy, but unless I'm upgrading something again I try to complete a system all at the same time.
You may be right. I’m going to look into the Whipple and compare pricing. The Whipple may be the way to go.The SC and all supporting mods should be done at the same time. The rails and plugs are easier to get to when the SC is off. 2.5 seems a bit aggressive for street use but I could be wrong. Headers can be done with or without the other mods.
If you’re going for high Hp on E85 you might be better off with a whipple. Considering what you pay for the SC porting, brick, water manifold, throttle body, rails, pulley, intake, etc, you aren’t too far off from the cost of a whipple.
Honestly if it wasn’t for me finding some sweet deals on the same but lightly used parts I’d be doing a whipple too.You may be right. I’m going to look into the Whipple and compare pricing. The Whipple may be the way to go.
When you go to these depths you might even consider a 3.8 whipple - fuel rails are included will make 900whp+ on 93 and 1000whp+ on E85 with the biggest pulley (lowest boost)So I'm fixing to start upgrading my 21 and I have a list of mods I want to do to it. I would like to get some feedback on what I need now vs what can wait to be bought and installed later. I've been reading and it appears that the fuel rails could be added later, and the Gforce axles upgraded later. Anything else I'm missing or other suggestions?
Seems like a big nothing burger. Rob left PBD and went to work with another shop. PBD still has tuners. Facebook had all the same rumors and conjecture. I talked to Mike at PBD about it, and he says there’s no story to tell, Rob decided to move on.A thread on another site suggests there is something going on @ Palm Beach's tuning staff..
Interesting developments at Palm Beach Dyno
www.svtperformance.com
I think when it comes to a big time tune. A tune that pushes the envelope with max HP without blowing your engine, Rob is the man, just my opinion.Seems like a big nothing burger. Rob left PBD and went to work with another shop. PBD still has tuners. Facebook had all the same rumors and conjecture. I talked to Mike at PBD about it, and he says there’s no story to tell, Rob decided to move on.
A tuner would probably be able to answer that one better.For those running the Whipple. Is it worth it to have the race port done? Does it make that big of a difference? Also, what about dropping down to a 3.75 pulley for a lb more of boost?
Ported will make more top end and slightly less low end but enough to make a difference in durability in the long run. Ported will give you more HP while making less torque, torque is the engine killer in high HP cars. You want to keep the torque around 800-850 with the 3.8 (lower than 800 is even better) to give the motor more durability.For those running the Whipple. Is it worth it to have the race port done? Does it make that big of a difference? Also, what about dropping down to a 3.75 pulley for a lb more of boost?
