Thanks 6-Speed, good information. I am still looking for a number to end up with after the adjustment, or is it just b/t 0-5 like the other site says. I have a one piece DS and a J&M UCA, so I know there will need to be some adjustment for lowering more than 1''.
no..installing a one piece DS does not require pinion angle change unless you are lowering the car.Is it true that if you are going to mess with the pinion angle you need a one piece drive shaft?
yes. normally 0 to -2 angle is where you want to be.BJ, is the opposite true, if i lower with FRPP, add in the J&M's, and the one piece DS, will i have to adjust the angle?
This should help a little....did a search and nadda come up. I am lowering the car with some springs,
1.2'' and need to adjust the pinion angle.
