Can you make the Speedo red, the guages white and the tach blue? and if so how??
Racer, it's very easy to do. Just keep pushing the 3 buttons up top until something happens. The worst you can do is throw off your shift points. WAIT - JUST Kidding! Don't do that!! It's easy to do, just follow the instructions manual. That's the first thing I started paying with when I bought mine.Can you make the Speedo red, the guages white and the tach blue? and if so how??
If I'm not mistaken, to change the colors also requires you to be in neutral and parked. Again, I think that's how I did mine but it's been so long since I last did it. At worst, the car will only be $2 less in value when you break the seal on the manual. You can also change the color to PINK if you like - LoL.![]()
flip
You can. Mine are set to Red-White-Blue.yeah there is about 250 colors........one click at a time......not sure on the exact amount of colors.
to answer the question I dont think that you can make it red white blue
with out looking right now . I think the color of the speedo and the color of the gauges half to be the same at all times. I think that you can only make red and blue. with the tach being blue. or vise vurse.
I will half to play with it more.....I only messed with it for about 2 min. Then I made it all red.You can. Mine are set to Red-White-Blue.
Thats what i want mine set at!You can. Mine are set to Red-White-Blue.
Yeah it is really simple to use. the hard part is diciding which color you want.The My-Color feature is fairly simple to use, a little patience and you will have it figured out in no time
But what if you are Color Blind? What then?The beauty of it is that if you can't decide then simply use a different color every time you use the car
You'll have a lot fewer options.But what if you are Color Blind? What then?![]()
LOLYou know the guy is color blind because he is the one driving the only Purple Shelby with Orange stripes![]()
