1 - 15 of 15 Posts
I started changing my motor mounts tonight.I got the drivers side done.I hope to do the passenger side tomorrow.This was not an easy task for me but it is half done.The other side should be a little easier.I used Prothane "bullitt" type motor mounts.They are billett aluminum with red urethane bushing.They come in red or black.Red being the fastest,naturally!
FYI=The stock motor mounts are stamped steel with rubber and are liquid filled so be careful if you do it yourself.Its a couple more pounds lighter now.Trying to shed about 350 lbs.If you search around you can find them for about $125.00.
07 SHELBY,
Those mounts are nice.
350lbs? Wow!
Are you targeting front end weight or all around?
How much do you figure you've improved the weight by so far?
07 SHELBY,
350lbs? Wow!
I'm sure I'll never get that but I've dropped about 30 to 40 lbs.
WOW 07 .:eek: :eek: :eek: Now that was a shot across the ole hood!!!!!!!!!!!!!!!!!!!!! You;re turn!!!!!!!!!!!!
Discussion Starter · #7 ·
I am going to just keep working on my car.I am not that big of a person so I have to find ways to get the weight off my Shelby.
Discussion Starter · #8 ·
Well I stopped by Subway on the way home from work so I could get back under the Shelby to finish the job at hand.The passenger side took all of 25 minutes(vegetarian sub,no sauce).I took a couple more pictures for those of you that are really interested.
Ive got those going in next Thursday as well.
Discussion Starter · #10 ·
Discussion Starter · #12 ·
not a mount guy myself, but those replacements look shorter. was there any diff in alignment of the engine. cool hat, special made?
No different in alignment.The hat was bought online a couple of years ago.
wheres the mounts that you lower the motor with
1 - 15 of 15 Posts
