Guys, I was going to clean brake dust from inside wheels tonite. Jacked car up and put stands under it. Crawled under and noticed that lower radiator valance had two bolts that had pulled clip nuts out of front crossover. Removed the only one that was still intact and finished dropping down for a look see. It had in fact pulled the two mounting nuts out. This valance does have a hook on each end that goes in to crossover as well to help suspend this piece. removed bolts from valance 7/32 if I remember correctly, nuts were still attached tightly to valance. I attempted to straighten, just so I could reattache until I can get a couple from dealer. You might want to check yours. These bolts hold just the rear of valance it is not going to fall out, but it sure can be flopping in the wind, especially if you lose all 3.
This piece is well underneath directly behind the lower front spoiler that we are banging all the time. Lying under the vehicle you will see w/shield washer btl directly to your right. Hope this helps.
ILLEGAL
ILLEGAL
