A little oil on the end and it went with just a little effort ,OK extra effort. LOLGood work! Did you have fun putting that 1/2" hose on the PCV quick-disconnects? It was a PITA for me.
Also did you fabricate the bracket for the Watts filter?
Svtbird91,A little oil on the end and it went with just a little effort ,OK extra effort. LOL
The bracket came with it.
A larger bowl will be a must on this along with frequent monitoring ( hopefully available soon).
Yes on both questions.http://www.conceptualpolymer.com/new_page_1.htmSvtbird91,
Is that a Watts unit ? Looks like the one I am wanting to use. You may have helped me out here. Is that the 1 ounce unit ?
Thanks ILLEGAL
+1!!Looks very nice.The coil covers look good too.
Yes on the coil covers. Thanks!+1!!
Did you do the coil covers like Badboy did it?
Also, I know there's been some "conversations" about how the catch cans DO work, but only for a little bit, then once it reaches a certain amount the can won't catch any more. I believe Jay said this a while ago.
Are you going to be watching this? As in - see how fast it takes to get to a certain level - then watch to see if it levels off and doesn't work past that level.
Thanks!
Great, thanks George.Yes on the coil covers. Thanks!
As long as the seperator can handle the rate of flow through it there should be no problem but I will have to monitor the volume that is acumulated so it doesn't fill up. This is especially important since there is no bypass.This is why I want to get the larger container.
Time will tell.....I will be watching this closely.
George.....
I used some oil on the ends too. I also used a hair dryer to heat up the hose ends to make it more pliable.A little oil on the end and it went with just a little effort ,OK extra effort. LOL
YesAre 1/2" hoses used w/ this?
Your quite welcome.Thanks again for all the help.
Don't mention it .Why thank you.![]()
