JLT Performance is launching some more Carbon Fiber pieces soon.
The stuff looks awesome, and I got my chance to try some out.
I picked up the radiator shroud cover and the fuse box cover today.
If you have the C/F intake, these pieces are a must have.
Installation of the parts is extremely easy, first start with removing the radiator cover...
Gently pry up the center pins, then remove the clips...
Install the new part and attach w/ the previously removed clips...
Pieces look awesome...
Fuse box cover is easily attached w/ two way tape. 3M of course, JLT doesn't compromise even in the small details.
Clean surface w/ supplied alcohol wipe...
Remove backing on tape...
Position gently in desired location, then press lightly to adhere the tape.
Very easy to put on and compliments the C/F intake piece.
Note, no more ugly prop rod junk!!
Available here...
http://jlttruecoldair.com/gt500.htm
Available here...
