You can do it easier (one step) and cheaper.
Go to evoperform.com and get the Stage 2 setup. Pulley, CAI and tune all in one, and the tune is setup for those specific components. One stop shopping.
That'll net you 525-540rwhp in one shot.
Unless you're going TVS or anything for MORE power than that, a full exhaust is not needed. You won't see big gains, but you'll spend a LOT of dough.
Get the KR exhaust, it's not expensive, sounds better than most any other exhaust, and there is absolutely NO drone at any rpm level. The weight reduction, and freer flow will get you about 15hp more give or take. $500 for 15hp, or $2,000 for 20hp.... there's the difference. And honestly, the KR's will sound better.
If you really feel the need to throw more money out there, use it more wisely. UCA/LCA's are a must, even at stock power levels, to eliminate the terrible and harmful wheel hop.
A new, larger, better heat exchanger will keep you out of heatsoak and give you more power for longer. That's about $450.
One piece driveshaft will also be a big help.
But aside from those extras, trust me... just doing a Stage 2 and KR's will make you realize just how much power can be unleashed from these things.
