yep - that's what Amy (SAI Prez) posted. something about "never", but we know "never" isn't as long as it used to be.I don't believe the carbon fiber KR hood will be for sale from Ford or SAI.
I know my fiberglass hood is 13 lbs. more than stock.Ahh... off faster than a prom dress... Next they'll be selling hood-lock bolts with a special design cut into the bolt head....
Speaking of Carbon Fiber, Fiberglass, and Aluminum - how much does each hood weigh? I understand Carbon fiber is probably the lightest, followed by aluminum, then FIberglass would be what I expect. Difference has got to be neglibile (no more than 20 pounds variance ??)
TD
You can make up for most of that by going to the '08 flywheel damper.I know my fiberglass hood is 13 lbs. more than stock.
I think I'll do that.You can make up for most of that by going to the '08 flywheel damper.
What's a flywheel damper ?:You can make up for most of that by going to the '08 flywheel damper.
You know what I meant. I've called it that all along, pretty much knowing it was wrong. What does the "unofficial" engine book call it?What's a flywheel damper ?:![]()
A Crankshaft Damper of course.You know what I meant. I've called it that all along, pretty much knowing it was wrong. What does the "unofficial" engine book call it?
