1 - 20 of 24 Posts
Supporting Vendor
GT500 "HALO" Angel Eye Kit! Single / Multicolor Options! Fits Stock Housings
***We have sizes for every GT500 headlight and fog light***
SMD Ring Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. Diode Dynamics' angel eyes are the highest quality and brightness available. We encourage you to shop around, you will not find better angel eyes for these prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
Our multicolor rings use SMD technology, a modern type of LED that provides a bright forward-firing light, creating a circle of light inside the headlights.
Our newest product, RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a WIFI controller option which allows you to control them via smartphone app.
Kit includes:
  • Two (2) Multicolor RGB SMD Rings, fitted for your vehicle
  • RF 28-Key multicolor remote, to change the color OR Upgrade to Wifi controller
  • Diode Dynamics Plug-and-Play Wiring Harness
  • Installation guide
  • Three year limited warranty
We use custom-manufactured SMD rings through our top LED manufacturer, with high-grade AAA resistors and LED chips. They are highly durable, with a black backing color. The LEDs go all the way around the ring, for no "break" in the light as with other angel eye designs, and are ten times brighter than old fiber-optic type rings.
Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
GT500 Headlight Angel Eye Kit
GT500 Fog Light Angel Eye Kit
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
****We have sizes for every model year**** More listings to come!
Research Angel Eyes here on our site: Angel Eyes - Research
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics HD Halos installed
Photo by: PS_Lighting_Solutions
Re: FS: GT500 "HALO" Angel Eye Kit! Single / Multicolor Options! Fits Stock Housings
do these fit the 11 - 14 model year also?
thanks
How are they installed in the sealed headlight?
Do you have to bake them in the oven?
Supporting Vendor
They will require you to bake the housings in the oven to separate the lens from the housing.
It's actually very simple with the 2007-2009 GT500 headlights
If you have any questions about the installation, feel free to give us a call: (314) 205-3033
Nick C.
I emailed you about a 2011 and you said you do not have a solution...is that what is meant as pointing me in the "right direction"?
Supporting Vendor
We certainly do have ring sizes that will fit in a 2011. I'm not sure who made that comment, but please send us a PM and I will provide you with more information for your 2011.
Nick C.
Couple ?
1. If you get the headlights and fog lights, do they both need their own wi-fi controller or can (1) $75. controller control the color on both?
2. Do you have the diffusers for the fog and headlamps or just headlamps?
Thanks
Supporting Vendor
Couple ?
Thanks
1. You can control them both from one controller. They will be the same colors.
2. We don't have the diffusers for the headlights, but the COB rings don't have the dotted look at all.
Feel free to give us a call if you need more information: 314-205-3033
Nick C.
We have sizes that fit the 2011-2014 headlights. If you send us an email, we can point you in the right direction
[email protected]
Nick C.
Nick C.
Supporting Vendor
Discussion Starter #11
Nick C.
We have more ring sizes on our site, if you are looking for rings for your 2011, send us an email or give us a call and we will give you the size information.
It's most likely a 100mm ring FWIW
Nick C.
Re: GT500 "HALO" Angel Eye Kit! Single / Multicolor Options! Fits Stock Housings
i have the headlight ones installed but how do I install the fog light ones? i have the fog light housing out but i cant seem to separate the fog lights lens from its housing. i baked the fog lights at 300 for 10 minutes. im scared to go any higher than that. and its almost impossible for me to find a local shop to do the custom work for me. in a bit of a pickle
Supporting Vendor
Discussion Starter #16
The fog light lenses have to be cut open, typically a dremel works best.
You might take another look at our dealer map if you are looking for professional installation. We just added over 150 new dealer addresses to the map!
Thanks,
Nick C.
Supporting Vendor
Discussion Starter #17
NEW! HD Halos and Strips!
Diode Dynamics is excited to announce our new HD LED Halos and Semi-Flex Strips are now available! Offered in switchback and single colors (red, amber, blue and white), they are perfect for custom applications! The Strips are available in 3, 6, 9 and 12 inches and the Halos are offered in universal sizes from 50-160 millimeters.
Both products were designed from the ground up and manufactured in our facility here in St. Louis, Missouri. They are backed by our hassle-free 3-year limited warranty.
Click here to shop
1 - 20 of 24 Posts
