1 - 20 of 26 Posts
Supporting Vendor
GT500 Footwell LED Kit! RGB Multicolor & Single color options! Control w/Smartphone!
Looking to add a fresh look to your GT500's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your vehicle.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. After months of planning, we have designed new LED strips to be used in this kit, which are highly flexible, waterproof, and long-lasting. This kit also uses our brand new RGB Multicolor products, which are controlled by the included remote! You can change the color to fit your mood, or adjust the brightness to your preferred settings.
Included in the kit:
  • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF sensor and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • Three-year Diode Dynamics worry-free full warranty
  • 30-day satisfaction guarantee
Also included with rear footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Re: FS: Footwell LED Kit! RGB Multicolor and Single color options! Everything include
Can you tap into cargo light where then turn on and off with door?
Supporting Vendor
You can wire them up to come on with the dome lights, but it does make the installation considerably more difficult
It's easier to tap into the 12V source in the center console and install a switch IMO
Nick C.
Sent pm
Got the se hooked up and tapped them to door jams with a switch so when switch is off they work with doors but you can flip switch and they on with doors shut...
1 - 20 of 26 Posts
