1 - 20 of 131 Posts
Supporting Vendor
GT500 Fog Light LED Bulbs! Plug & Play install! Match Factory HID/DRLs! USA Made SLF!
Shelby GT500 Fog Light LED Bulbs
Diode Dynamics LED bulbs for replacement of your Shelby GT500's fog lights, in all major sizes. This will make your GT500's fog lights a nice bright white, to match factory HIDs & LED DRLs! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
We also offer three options in brightness:
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF:Street Legal Output. Much brighter than factory. These are bright! USA Made! 5,700K Color Temperature
*SLF matches the 2013-2014 GT500 Factory LED DRLs perfectly!
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Shelby GT500).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: Fog Light LEDs for 2007-2014 Ford Shelby GT500
Diode Dynamics: Multicolor Fog Light LEDs for 2007-2014 Ford Shelby GT500
Any questions, feel free to ask via email ([email protected]), Post, PM or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
Customer Review:
"Bought the stage 3 white for my 11 GT. Matches real nice with my 6k HID and installed in literally 5 minutes. Awesome addition to my car, def adds to the front end" (Posted on January 9, 2014)
Re: FS: Fog Light LED Bulbs! 4 Brightness Options! Plug and Play upgrade! For All Yea
You have any that will fit the fogs in my 13 F150?
Supporting Vendor
Discussion Starter #3 (Edited)
Thanks to Nick C's guidance I have received replacement LED'S for the fog's, license plate, and trunk. Plug and play, easy install, and I am very please with the results.
how do I post pics?
Nick C. The nighttime output is better than stock.. in my experience.
However, I hated the color of the stock fog's so much that I would rarely turn the stock fog lights on at all. Now I find myself turning the new led fog's on in the daytime LOL
im in... ordered the XP80 cool whites:sunny: Should be a marked diff. over the (flash lite bulbs) !!!
Reactions: Diode Dynamics
Supporting Vendor
Discussion Starter #11
The XP80's are significantly better than the factory bulbs, and they look 1000x better as well!
Thanks for ordering with us!
Nick C.
Re: FS: GT500 Fog Light LED Bulbs! Plug and Play install! For All Years! Matches Fact
Diode Dynamics is pleased to announce a new color for our popular XML2 fog light -YELLOW! The XML2 utilizes genuine CREE XML2 components, for a true, measured output of 1,420 lumens. 100% plug-and-play. Sizes available include 9005, 9006, H8, H10, H11, H16, and PSX24W.
Thanks!
Nick C.
Could you post a pic of the new Yellow compared to the comparable White....on a GT500?
I have the White units on my 2012, thinking seriously about the Yellow...
Supporting Vendor
Discussion Starter #14
The actual lumen output is identical to our other XML2 LED options
They are measured at 3,000K in color
I don't have a photo of them installed in a GT500 yet, but they produce a great looking yellow IMO
Give us a call if you have any questions: (314) 205-3033
I'm personally considering a set of these for my GT500 fog lights as well. They look really cool when they are off as well
Nick C.
Re: GT500 Fog Light LED Bulbs! Plug & Play install! Match Factory HID! Yellow XML2 Op
question .... does the bulb draw more amperage than the stock possible putting a overload on the factory wiring.
Second question, using one of the higher bulbs how does the heat effect the casing on long drives ?
don
Supporting Vendor
Discussion Starter #16
The LEDs actually draw substantially less output than your factory bulbs, so they are very safe for the automotive application
They also create less heat than your factory halogen bulbs, so they won't create any risk of heat-related damage to the housings
Nick C.
Supporting Vendor
Discussion Starter #17
The Yellow XML2 looks incredible on this 2003 Terminator IMO:
Nick C.
I want a set of the pure white fog led for 07, which one are they?
Supporting Vendor
Discussion Starter #19
Thanks Nick got them ordered
1 - 20 of 131 Posts
