1 - 4 of 4 Posts
I have a 2007 GT500 with only 11,000 miles, i noticed the last couple of times I pulled it out of the garage, that there is a small amount of black dust (looks like brake pad dust) underneath the bottom on the engine, probably my guess may be from the clutch. Any indeals?
Supercharger belt slipping? Is the dust on the garage floor?
If its the stock clutch get rid of it quick. They are no good.
Check behind the supercharger pulley to see if the front belt is slipping. If it's not that then it may be the clutch unfortunately.
Welcome to the forum!
If it’s not either item mentioned above, make sure it’s not a slight oil leak with road dust caked on.
1 - 4 of 4 Posts
