1 - 17 of 17 Posts
2021 GT 500 Twister Orange with black stripes
Jut took delivery of my 2021 GT500. I have a 4 post life which used to house my 70 Nova. Now with my GT500 replacing that, the car is about 5 inches wider. The outer lips of the front tires barely fit on the outer lip of the lift tracks. Also, with my nova , I could hang out the window and guide the front tires onto the ramp with my eyes but with the GT500, I cant seem a damn thing.
It's so tight that I dont want to be playing with fire. Is there a camera or laser sensor that can help? I sure someone else out there has a lift that they solved this problem with some type of gadget.
Any advise is much appreciated.
My advice is to back onto the lift. I back into my 2-post lift… I use a combo of the backup camera as well as the side mirrors angled down watching the rear wheels.
Im not sure I can do that as I have a I-Beam running accross my garage ceiling that would hit the car in that orientation.
Use a helper to guide you in or an iPad/iPhone on the outside that you could FaceTime and use the video feed for guidance.
Reactions: 2112 and AZ21GT500
I dont have the luxary of a helper when I am coming home late at night. Is there a wireless camera I am mount on the fender?
GoPro cameras feed video to phones.
Reactions: AZ21GT500
2021 GT500 HP Carbonized Metallic Gray
Add a ring doorbell to the wall in front of the lift and use the app to watch your approach. Might work?
2021 Shelby GT500
Some folks have added a front camera to their grill to prevent scraping their splitter, I bet you could do the same. I don’t have one so I can’t recall which brand or where they got it but some folks found a way to tie it into the stock Nav screen.
Ruby Red 2014
2020 Shelby GT500 Performance Blue
Strategically located mirrors mounted on the wall?
This is what I did. I have a similar situation (4 post lift, barely enough room to squeeze the GT500 on it). I placed a mirror in a location where I can see the tires/lift on the drivers side. Has worked well for me. Prior to this setup, I had my wife guide me every dang time, lol.
Discussion Starter · #11 ·
Where did you mount the mirror? Also, it must be challenging at night to see?
When parked on the lift, the mirror is mounted on a wall next to the drivers side door. It is roughly level with the car’s mirror (while on the lift) and pointed down so u can look out the drivers window and see the rear tires while parked. On approach, I can see my front tires and after a point switch to watching the rear.
As for lighting, I guess that all depends on what lights you have turn on when your garage door opens. So YMMV on that one.
Discussion Starter · #13 ·
Would you be willih to provide a pic of the mirror and mounting ?
Discussion Starter · #17 ·
I just purchased 4 Wyze v3 cameras from amazon. Gonna mount them our back of lift and on front walls so I get a 360 view. $130 total. They stream 30 fps and are 1080p and have night vision
lets see
1 - 17 of 17 Posts
