not that I know of but then again I'm a great mechanic until I step in the garage...Just going to siphon some less than fresh gas…the lazy way.
bypass fuel pump and drain from fuel line.
Is there a tip for depressurization fuel line before disconnecting
whoomp there it is! 3/8" disconnect tool will help a lot. also the line is going to be pressurized and spray like a little fire hydrant so have rags ready. best to do it after sitting for 6 hrs or even over night.
whatcha installing, proflex commander?
🤣🤣 it was recommend to pull the fuel pump relay, crank the car, and since no new gas will be pumped into the engine with the relay pulled…it will empty the fuel rails = depressurized.not that I know of but then again I'm a great mechanic until I step in the garage...
I did something similar on my 2017 GT Mustang 2 years ago, you are correct Chad, remove the fuel pump relay in the fuse box, ( black box in front of the car) and your fuel pump is off.🤣🤣 it was recommend to pull the fuel pump relay, crank the car, and since no new gas will be pumped into the engine with the relay pulled…it will empty the fuel rails = depressurized.
Thank you for the added confidence. I am still a rookie for sure at attempting to be a car mechanic…and then acknowledging I am learning on almost $100,000 pure beast!I did something similar on my 2017 GT Mustang 2 years ago, you are correct Chad, remove the fuel pump relay in the fuse box, ( black box in front of the car) and your fuel pump is off.
I did this for another reason, just confirming you're right.🤷♀️
I was a pretty good mechanic on old school Muscle cars, these Newer cars I am like you learning as I go, Yes learning on a 100K plus car is daunting task. Like you Asking Questions on here is smart, before doing something that can F up your car.Thank you for the added confidence. I am still a rookie for sure at attempting to be a car mechanic…and then acknowledging I am learning on almost $100,000 pure beast!
your insight is super appreciated
Good questionwhat’s your motive Chad (@coach)? Is this to siphon out oxidized gas?
Yes. Exactly. Trying to have my cake and eat it too.Good question![]()
I haven’t driven in two weeks. Should I worry about any pressure that would spray an excess amount of gas that a couple of blue shop towels couldn’t absorb?If you're disconnecting the fuel line, the fuel that's actually pressurized is only a momentary burst. The rest of the fuel in the line isn't going anywhere until the system is opened up and that's where the bulk of your lost fuel will come from. Just make sure the engine is cold and use shop rags or the blue paper towels around and below the connector. Many fuel systems will lose fuel pressure overnight, so refrain from priming the pump by priming the fuel system with the start button.
Two weeks, You shouldn't have much spray if your mistress has been sitting that long. Catmonkey knows a lot about these cars.I haven’t driven in two weeks. Should I worry about any pressure that would spray an excess amount of gas that a couple of blue shop towels couldn’t absorb?
Edit: glanced over others’ fuse recommendation. Sure that’s also fine.
Behind the cloth trunk liner on the driver's side are harnesses for the two fuel pumps. Each has a yellow, sliding lock that you slide out of the harness and the harness will then unclip. Start the car and it will stall out = no fuel pressure. Connect the harness back once you're done and you're good to go. I have done this several times. Seems complicated but it's not.
I forgot, A lot of you who live in the USA, put your cars in hibernation, do to weather, Here its never cold, rainy season, my 500, may go 10 days to 15 days sitting without driving it, but I usually always start it up and run it 30mins if I don't drive it, Rainy season here we'll get 150 inches a year, 100 to 120 of that is in a 3 month period, So flooding in and around town is a concern.Yes. Exactly. Trying to have my cake and eat it too.
Keep miles low so I can enjoy it a long, long time.
If life throws me a curveball, be able to recoup my initial investment.
But when I do drive it, have a blast in it.
fresh gas is critical to bringing this fuel circle. Already got ethanol free 93 in the tank. It’s about 3 months old (from pump) so probably older.
figure if I get fresh in the tank, when the next pretty day comes I can thoroughly enjoy my joy ride 😎
You should worry about that animal inside the car that wants abuse through right pedal pounding! It may come for you in your sleep if you don’t drive it more 🤣I haven’t driven in two weeks. Should I worry about any pressure that would spray an excess amount of gas that a couple of blue shop towels couldn’t absorb?
