1 - 10 of 10 Posts
2.9L Gen 2 Whipple (for 2007-2014 GT500s)
$2000 shipped (will consider reasonable offers)
Used for about 600 miles, driven to car shows. Never raced
You can choose one of these two pulleys to come with it:
3.25 (for 91/93 octane, 16lbs of boost)
2.875 (for E85/race gas, 21lbs of boost)
Buyer pays paypal fees if you don't want to use friends/family option
Located in Los Angeles, CA
205481
205482
205483
205484
205745
Awesome supercharger! Good luck with your sale Austin. If anyone needs an install guide, I put one in the DIY section.
Reactions: SVT_Austin
Hello, I was wondering what injectors and fuel pump you ran with 3.25 upper. I am considering your whipple, thank you
joe
joe
The smallest injectors you can get away with I believe are 56lb injectors. ID1050x's were used with this. Stock fuel pumps were used, but needed to use Fuel Pump Boosters aka BAPs
Thank you, I am researching this as opposed to a 13-14 tvs. I know I can make bigger power with yours but I am looking also for a simple install process that I can do
@Goose17 I believe has a install process for this.
The whipple and the 13-14 TVS are direct bolt on replacements can reuse stock hardward as far as I am aware. May be wise to give a quick call to whipple to make sure there's nothing else needed for your year.
That's a good idea, I was thinking of 72lb injectors and vmp boost a pumps. Car barely has 6000 miles so clutch should be good
1 - 10 of 10 Posts
