2008 Shelby GT500 Coupe 5.4 ltr 4v DOHC 4 cam SC EFI OBDII CD/CD-R/DVD-R
For those DIY’ers with burnt/charred BEC wire terminals on your 12 awg wires that lead to the high speed cooling fan relay as well as the low speed cooling fan relay via the fuse box under the hood… (Green/Violet wire & Green/Yellow wire).
If you’d like to remove and replace the charred terminals with new ones, I believe I’ve located the correct terminals on Amazon. I ordered a set myself and will arrive friday, when they do arrive I’ll confirm weather or not the terminals end up being the correct direct replacements for the original terminals.
Link for terminals on Amazon
12-10 Ga. Tangless Sealed Female Metri-Pack 280 Series Terminals #12110853 - (Pack of 50) 12-10 Ga. Tangless Sealed Female Metri-Pack 280 Series Terminals #12110853 - (Pack of 50) - - Amazon.com
