Has anyone installed a Fomoto oil drain valve (F-106N) on their car and if so, any clearance problems?
Cheers,
Doc
Cheers,
Doc
The Oil on the Cross Member is from changing the filter, not from the drain plug. I jsut put about 3-4 shop rags over the cross member to absorb the spilt oil. It worked for me.You would still need some tubing to prevent the oil from running all over the cross member correct?
I have used one on another vehicle. They tend to drain slow. No other complaints. opening valve WILL be intentional. Safety ledge (recess) built in so that you must push back and over to open, also spring loaded.Has anyone installed a Fomoto oil drain valve (F-106N) on their car and if so, any clearance problems?
Cheers,
Doc
Same here .I think I'll stick with the old fashion way - using a 16mm wrench.
