Fail safe Engine Mode - 2009 GT500 (battery)
203 Views 4 Replies 5 Participants Last post by  Imatk
Engine would crank, start, die and throw up fail safe engine mode. Seemed the starter was spinning the engine a little slow. Tested the battery and it was weak. Installed a new battery and it would spin the engine fine but would not start. Scanned it and the code was “control module failure“. Cleared the code and it started up immediately. Several forums and 2 techs said a bad battery woul not cause fail safe mode. Well, I guess it can. By the way, the old battery was 8 years old. I had kept it it on a battery minder desulfator maintainer.
1 - 5 of 5 Posts
Hello, I see you’ve been a member for quite sometime and if you are up for introducing yourself and showing us your ride, you’ll find our new member area here:
New Member Introductions
Please click your upper right avatar/account settings/vehicle details and enter your car year. It then shows under your screen name, which helps in conversations here. We cover multiple years of the GT500 on this forum. (Remember to click Save)
Also, we encourage everyone to put their first name in their signature to make this place more friendly (click your upper right avatar to get there)(You’ll need to save this as well) Let us know if you have any forum questions.
Forum picture tips:
You can use the rectangle icon to upload single full-size shots. Option 2 is the paper clip icon for multiple shots (up to 10). The paper clip icon will give you clickable thumbnails unless you select “Insert Full Images” before posting the thread.
  • Helpful
Reactions: 1
I see you have been a member since 2014, but this is your 1st post, so welcome! Please add your car year under your screen name.
Reactions: 1
Just an idea... it's possible that your alternator died. I don't know what code you got but they are known to crap out after a while. I went through three of them before I got a Nations and was done with it.
And if it IS your alt, make sure you get the correct one for your year... I think the regulator is different on different years.
Reactions: 2
1 - 5 of 5 Posts
