.I recently bought my first Shelby 2013 gt500 with 4k miles and couldn't help but notice the annoying drone around 75mph. I thought this car was stock but now second guessing because I also found a sct tuner with a headers CEL tune.
I know my father's 2022 Shelby has no drone at all.
Is this normal for a stock 2013 gt500?
Maybe get back with the seller & ask more questions, there's a lot that's not stock, besides the wheels & axle-backs.
As you found an SCT, you need to find out who's tune is on the car.
The rocker stripes are not OEM, which could explain the front seats, which are the default on a stripe delete build.
How about a pic of the engine ??
I just installed passenger and driver side catch cans like 2min ago lolEngine bay “looks” stock except the battery. I would get yourself a passenger side oil catch can. As @Cobra4me confirmed, the axle back is aftermarket. I would start there after confirming if the rest of the exhaust is factory. Easiest way to do that is get it up in the air.
The driver's side catch can is pretty useless, gathers little or no oil. Can you return it? Most of us never installed one because all of us found it was decoration only! Can you order factory mufflers from your local dealership? I loved the stock exhaust sound as it was perfect for my needs.I just installed passenger and driver side catch cans like 2min ago lol
I will get in the air probably this weekend and report back.
I plan on tracking the car so I figured better safe with 2 instead of just the one. I can probably find some stock mufflers just so I can really see the difference.The driver's side catch can is pretty useless, gathers little or no oil. Can you return it? Most of us never installed one because all of us found it was decoration only! Can you order factory mufflers from your local dealership? I loved the stock exhaust sound as it was perfect for my needs.
Yep should be an h from the factory. If it has headers there will be a flanges where they meet kindve parallel to the bottom of the car. If not then the midsection pipe will angle upward towards the stock/shorty location with no flange until it gets up thereI plan on tracking the car so I figured better safe with 2 instead of just the one. I can probably find some stock mufflers just so I can really see the difference.
Do you know if these cars come xpiped factory I do remember seeing that the last time I was underneath and thought it strange since my last car was a 2013 mustang GT and it was Hpiped
So stock should look like this?Yep should be an h from the factory. If it has headers there will be a flanges where they meet kindve parallel to the bottom of the car. If not then the midsection pipe will angle upward towards the stock/shorty location with no flange until it gets up there
Nice that’s a badass exhaust you got then. You could pick up some power if the tune isn’t right but it sounds like the car is already tuned for headers and not having cats which is probably where I would keep it. Maybe have a tuner put the car on the dyno with a wideband and make sure the tune is safe, if it is then no sense getting an updated tune especially since the newer software will not be able to turn off your CEL. Your current tune was written before the EPA did a massive crackdown so no more of that. Also the drone is probably from what looks like a magnaflow type muffler. If you switch to Corsa sports or can find borla touring those would be not too loud with your current setup and not drone.So stock should look like this? View attachment 261760
And off memory this looks like what I have View attachment 261761
So if that's the case with a proper tune I should be able to gain some serious ponies?
So backing up. the reason I had to get under the car was to replace bank2 sensor 1 O2 sensor the CEL was on when I bought it. And when I checked with the sct scanner it says it was returned to stock but there is a tune for "headers CEL delete" and I didn't add the tune. My guess it has high flow cats. Because I've had no more CEL since replacement of the sensor.Nice that’s a badass exhaust you got then. You could pick up some power if the tune isn’t right but it sounds like the car is already tuned for headers and not having cats which is probably where I would keep it. Maybe have a tuner put the car on the dyno with a wideband and make sure the tune is safe, if it is then no sense getting an updated tune especially since the newer software will not be able to turn off your CEL. Your current tune was written before the EPA did a massive crackdown so no more of that. Also the drone is probably from what looks like a magnaflow type muffler. If you switch to Corsa sports or can find borla touring those would be not too loud with your current setup and not drone.
