1 - 8 of 8 Posts
who has installed one and are you satisfied? Any tips? One is on the way and should have it ready for install next week. Thanks.
if its the one piece alum dynotech...then your golden...pretty straight forward install. just make sure to evenly torque the adapter bolts, then DS bolts. (star pattern & cris-cross), and apply torque in increments, 25lb each until full torque is reached is normal.
I am not sure if EVO has dynotech, I know Lethal does. Can anyone chime in?
Do not know about their current DS of choice, but mine from EVO, way back, was Dynotech and no complaints here.
What is the torque spec. for the 4 driveshaft bolts? I recently installed a driveshaft safety loop and the instructions said to torque the transmission bolts to 55 ft/lbs but just said to retighten the 4 driveshaft bolts!
What is the torque spec. for the 4 driveshaft bolts? I recently installed a driveshaft safety loop and the instructions said to torque the thansmission bolts to 55 ft/lbs but just said to retighten the 4 driveshaft bolts!
the four DS bolts at the tranny are 76 ft/lb
the six bolts for the DS adapter at the pinon are 25 ft/lb
the four bolts for the DS at the pinion are 35 ft/lb
1 - 8 of 8 Posts
