Can anyone share what they have for a built bottom end? I'm freaking out, I have the mechanic i just need a block as long as nothing else is hurt. I have 10k maybe 12k. I want to be at 800 wheel safely.
Moved your post here to our performance mods section.Can anyone share what they have for a built bottom end? I'm freaking out, I have the mechanic i just need a block as long as nothing else is hurt. I have 10k maybe 12k. I want to be at 800 wheel safely.
Thanks for the back story. Sorry about the engine. I haven’t built one, but others here have. Hopefully someone will give you solid advice.My apologies I thought I had it in the right location.
Holes in the block. I'm thinking because I got intake temps too hot and intercooler pump failure codes last week that's a possibility.
I was data logging and temps looked OK so I turned off the laptop and started racing. Later that night i was letting off those lovely pops with my wotbox set at 3000rpm rolling in 2nd at 40 mph maybe. Seems odd because I have had the wotbox for 5k miles and last year let off way more aggressive pops at shows.
We looked at the road and it looked like I was dumping oil a block before I let of a 2step but who knows. 34k on her 613/632 wheel. Vmp tuned
Since my brother is a BMW master tech and he has a performance shop swapping over parts onto a shortblock will be easy. We play we pay. Maybe I was destined to have 800 wheel qnd the shortblock will be a blessing.
Came here to say the same thing. These motors don't like to be bounced off of the rev-limiter like a VQ at a Lowe's parking lot car show. Very likely that your WOT Box antics caused you to jump time and your pistons and valves all became friends.The WOT BOX wreaks havoc on the timing gears and chains. After seeing it first hand my during full build, I’ll never use the launch feature of the WOT Box again.
Bouncing off the limiter at any rpm isn't good on these motors. Timing chains and tensioners just don't enjoy it, even with the best stuff out there.I guess bouncing at 3k isn't good, was thinking that it would only be an issue bouncing at high RPM. Live and learn. Pitting a deposit on a 1200hp rated shortblock today. A very reputable builder had one on a shelf someone had built qnd never came back for. Hello billet gears. Should be back to hooning very soon.
