SAE is considered the standard that everyone goes by. STD will show higher numbers, and some shops use this to make the graph look better. I only go by SAE.What is the difference between SEA dyno numbers and STD numbers.
Yes. STD correction works out a little lower than SAE.So STD would actually be lower at Denver's altitude 5280ft?
At least we are all in the same boat!Yes. STD correction works out a little lower than SAE.
My SAE 507 rwhp is 505 using STD correction. Uncorrected it's only 420. That's what thisaltitude does to us.![]()
Yep. That's why I'm upgrading to the Evo Stage 2, 4lb lower pulley and a Stiegemeier port and throttle body. 18 lbs of boost, baby!At least we are all in the same boat!Forced induction is the only way to go at this altitude!
LMAO. Yea that'll ruin your whole night!STD's are not good,whether corrected or not.![]()
I hate when that happens.STD's are not good,whether corrected or not.![]()
Heh, good stuff.STD's are not good,whether corrected or not.![]()
