As the world leader in motorsports chassis dynamometers and diagnostic equipment, Dynojet Research Inc. is pleased to announce the Dynojet Wide Band 2, the second generation of Dynojet's popular Wideband Air/Fuel Ratio Monitor kit with digital technology and quickest response in the industry. All of this comes with a lower price and a more compact package.
The Wide Band 2 provides a complete picture for proper air-to-fuel ratio analysis.
The Wide Band 2 includes the following:
• 1 Wideband 2 Module
• 1 Data Acquisition Cable (optional with 15-7011 kit)
• 1 Bosch LSU 4.2 Wide Band Oxygen Sensor
• 1 Oxygen Sensor Cable
• 1 Oxygen Sensor Weld Bung, Plug, and Copper Washer
• 2 Dynojet CAN-Link Port Seal
• 3 Wire T-taps
• 1 Terminal Strip Plug
• 2 Dual Lock Strips
• 1 Alcohol Swab
• 3 Zip Ties
• 1 Warranty Registration Card
• 2 Dynojet Decals
• 1 Installation Instructions
Wide Band 2 Options:
• Dynojet LCD Full Color Touch Screen Display
• White or Black Analog Gauge, 52mm (2 1/16”)
• White or Black Digital Gauge, 52mm (2 1/16”)
• Data Acquisition / Gauge Combination Harness
• Dynojet CAN-Link Cable
Wide Band 2 Technical Features:
• 0-5v Calibrated Analog AFR Output (Connects to external data acquisition device)
• One wire RPM hookup
• 0-5v analog input (TPS, MAF, boost, etc…)
• Built-in Sensor Condition Test
• Durable enclosure and wire sheathing for years of trouble-free operation
• Dynojet CAN-Link communication, allows for expansion options
Wide Band 2 Product Specifications:
• Power Requirement 11.5 - 15 VDC, 3A
• Dimensions 2.80"w x .56"h x 1.488"d
• Range: .68 lambda - ambient air
Inputs:
• Analog: 0-5 VDC
• Digital Square wave, 0 - 12 V nominal (coil (-) tachometer signal)
Outputs:
• Gauge Driver 0 - 5 VDC analog
• Calibrated AFR 0 - 5 VDC analog
• Simulated Narrow Band
• Dynojet CAN-Link (accessory cable required)
Pricing:
15-7003 WB2 - Base Unit $249.00
15-7018 White Analog 52mm Gauge $69.00
15-7019 Black Analog 52mm Gauge $69.00
15-7020 White Digital 52mm Gauge $69.00
15-7021 Black Digital 52mm Gauge $69.00
LCD-200 LCD Touch Screen Display $299.00
FordGT500.com forum members receive an additional 10% discount off these prices!
For additional information, check out the WB2 website at http://www.dynojetwb2.com
If you have any further questions, you can PM me here, e-mail us at [email protected] or call us at 800-992-4993.
