1 - 5 of 5 Posts
2014 PP/TP W/R
Hello everyone. I recently installed a backup camera on my 14’ GT500. Now I have low surging idle when I tap the pedal, I have the orange wrench in the dash as well and also constant beep from the engine bay.
Where did you get your power sources from? Wondering if you created a short.
2014 PP/TP W/R
Installed a lockpick so it’s coming off of the harness.
Haven’t messed with that so can’t help… sorry.
When I wired my dash cam in my 2020, I tapped into two power leads. One was a constant on and the other was a switched source. Both were inside the passenger side fuse panel.
Reactions: tFlash21
2014 PP/TP W/R
if I re wire I will definitely look into that method
1 - 5 of 5 Posts
