1 - 4 of 4 Posts
Just curious. I've read conflicting info, but my car has them and I'll be replacing since these look fairly gnarly. Ford's website says these are "for lowered cars", so I'm confused.
208501
2012/2013 Hybrid
Ford Racing's snubbers were stock pieces for the 2011 up. They are a softer durometer which works well with a lowered vehicle. I usually cut them down to have some daylight between the frame and top of the snubber at ride height. If it sits on the bump stop, that's pretty much your suspension.
This is what it should look like.
208504
The mounting bracket is a relocation bracket to move the snubber inboard because I removed the factory bumpstop bracket. Otherwise yours would use the mounting bolt closest to you in the picture and there will be no other provision for a bolt.
2011 GT500
Thanks @Catmonkey. I need to check mine out for clearance as my 2011 svtpp rides like a haywagon on these stinkin Michigan streets. Maybe your suggestion is the cure.
Reactions: REMIX
Dang, yours looks like some mice or another varmint has been chewing on it!
1 - 4 of 4 Posts
