1 - 13 of 13 Posts
I have been noticing from time to time with my cooling fan that it will kick on at its regular preset temp (207-208) and go down to 199 where the fan kicks off.
But I have noticed that I can be sitting in traffic, the fan kicks on and my temps keep going down , say o 185 etc. So this happened again today but I was close to home so when I pulled into the garage I quickly popped the hood and sure enough the fan was still on ( hardly ever run the a/c so it was off)
Whats up here ?
2008 GT500 Convertible
You don’t list a Thermostat on your signature, but do you have an aftermarket one? Since you’re below stock 195 set. If stock, maybe it’s stuck open? However, fan should have turned off with a/c off.
As far as the fan, older relays can stick/short. That’s the only way (apart from a wiring short) the fan can run without ECU command. They are easy to open up and check with a screwdriver separating the halves. If you’re not comfortable, swap the hi and low fan relays and see if the high speed sticks now (assuming it was stuck in low speed) using a/c to get the temp higher while parked.
I’m looking into doing some upgrades myself because I’ve read that S197 mustangs in general have a high incidence of cooling fan issues. With the resistor on fan and the fuse box getting corroded.
What are you using to determine engine temperature. Are you using something that monitors the ECT sensor, or do you have an aftermarket gauge sensor? Has anyone modified your fan settings in the tune? What thermostat are you running? Mine runs in the 180-185* range, but I have a 170* thermostat and my fan settings are modified.
I have a nGauge monitoring ECT’s
I have a 170 thermostat
I also have the updated 1314 Svt fan
My car on the open highway Will run high 170s low 180s. Around town in open traffic about the same maybe a little hotter. In traffic moving where I have people in front of me and I don’t have clean air 190s and moving slow or at a stoplight it’ll go up to 207-208 and then the fan kicks in
You need someone to program your fan settings. If you have user defined parameters on your tune, you can do it yourself.
John
I've decided to get the CR radiator and have it shipped to VMP
I'll have them install it, by doing so I will get a complete flush of both the intercooler and radiator, and I will have them adjust the radiator fan while I am there
Take care of everything at one time
John
Put this in each system a few days before the drain/fill. Remove some coolant first to make room.
FLUSH!
Discussion Starter #10
FLUSH!
In other words get the system ready and get it cleaned out a few days before the new radiator goes in the FLUSH has been optimized
Discussion Starter #11
FLUSH!
thank you tim
When does your new GT500 arrive?
thank you tim
Just got word this morning that my build date slipped a couple days to July 10th. I expect it mid to later Aug.
Discussion Starter #13
fantastic !!
Bet you cant wait
1 - 13 of 13 Posts
