I don't have a Vert, but I am aware of this TSB. does anyone know it this window problem affects the top ?
CONVERTIBLE—REAR QUARTER GLASS— TSB 08-17-3
TORN/SEPARATING QUARTER GLASS DIVISION BAR
FORD:
2005-2009 Mustang
ISSUE
Some 2005-2009 Mustang convertible vehicles may
exhibit a torn / separating quarter glass division bar
due to misalignment between the front door window
glass and the rear quarter window glass. Concern
may be duplicated with convertible top down,
quarter glass down and front door glass up. When
the rear glass is raised, it may catch on the front
door glass creating a scissor effect over time. The
windows need to be aligned to each other and the
convertible top, as a glass system.
ACTION
Follow the Service Procedure steps to correct the
condition. Figure 1 - Article 08-17-3
SERVICE PROCEDURE
NOTE
FIX REQUIRES QUARTER GLASS
REPLACEMENT AND FRONT DOOR GLASS
ADJUSTMENT. THE DIVISION BAR IS BONDED
TO THE QUARTER GLASS AND CANNOT BE
REMOVED WITHOUT BREAKING THE GLASS. IT
IS NOT SERVICED SEPARATELY.
1. Replace the quarter glass assembly, the seal is
not serviced separately. Refer to Workshop
Manual (WSM), Section 501-11.
2. With the convertible top closed, remove the
rear side rail weather strip and close the rear Figure 2 - Article 08-17-3
quarter glass window. Adjust the quarter glass 3. Adjust quarter glass so that a constant
so that a 5/32² - 3/16² (4-5 mm) gap exists 5/32²-1/4² (4-6 mm) gap exists between the
between the glass and the convertible top division bar and the door glass. Also, adjust so
weatherstrip retainer. Use the quarter glass jack that the glass is inset 5/32² - 1/4² (4-6 mm)
screws to adjust inboard / outboard. Loosen inside the weatherstrip retainer. Apply tape to
nut. Use a 4 mm hex drive to wind the jack top exterior side of quarter glass. Mark a 5/32²
screw as needed. Tighten nuts. (Figures 1 and - 1/4² (4-6 mm) line on the tape as a visual aid
2) in adjusting the glass inset to weatherstrip
retainer. Use quarter glass attaching screws to
adjust the glass. Loosen both screws and move
the glass in plane as needed. (Figures 3 - 5)
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date August 18, 2008 PAGE 1
TSB 08-17-3 (Continued)
5. Adjust the door glass so that the door glass is
flush to the quarter glass division bar or
outboard of the division bar by no more than
1/16² (2 mm). (Figure 6). Use the door glass
window regulator jack screw to adjust glass
outboard. Remove the round reflector located at
the bottom of the door trim panel. Turning the
jack screw clockwise tips the glass outboard,
counterclockwise tips the glass inward. If
additional adjustment is needed, then remove
trim panel and use glass clamps. Refer to
WSM, Section 501-11.
Figure 3 - Article 08-17-3
Figure 6 - Article 08-17-3
NOTE
Figure 4 - Article 08-17-3 MISALIGNED DOOR GLASS WILL BOUNCE BACK
DURING OPERATION IF IT CONTACTS THE
INBOARD SIDE OF THE UPPER CONVERTIBLE
SEAL RETAINER. CONCERN MAY BE
DUPLICATED WITH TOP UP AND REAR
WINDOWS DOWN. DOOR GLASS MUST BE
ALIGNED TO BOTH THE CONVERTIBLE TOP
AND QUARTER GLASS DIVISION BAR.
PART NUMBER PART NAME
AR3Z-7629710-A Quarter Glass - RH
AR3Z-7629711-A Quarter Glass - LH
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
Figure 5 - Article 08-17-3 IMPORTANT: Warranty
4. Tighten screws and install the rear side rail coverage limits/policies are
weatherstrip. not altered by a TSB.
Warranty coverage limits
are determined by the
identified causal part.
PAGE 2
OPERATION DESCRIPTION TIME 081703D 2005-2009 Mustang 2.6 Hrs.
081703A 2005-2009 Mustang 0.7 Hr. Convertible: Replace Both
Convertible: Replace One Rear Quarter Glass And
Rear Quarter Glass And Adjust, Additional
Adjust. (Do Not Use With Adjustment Is Needed
29710A) Remove Both Interior Door
081703B 2005-2009 Mustang 1.3 Hrs. Trim Panels. (Do Not Use
Convertible: Replace Both With 23943A, 23943A13,
Rear Quarter Glass And 29710A)
Adjust. (Do Not Use With DEALER CODING
29710A) CONDITION
081703C 2005-2009 Mustang 1.4 Hrs. BASIC PART NO. CODE
Convertible: Replace One 7629710 07
Adjust, Additional
Remove Interior Door Trim
Panel. (Do Not Use With
23943A, 23943A13,
29710A)
