Jim I absolutely believe it! Mine was 17.5oz down. Good thing you caught it before it caused any problems.I finally had the weather and time to check my transmission oil level. I found a plastic syringe at a Central Tractor store, grabbed some tubing, put the car up on my quickjacks and off we go. Unfortunately the syringe only held 2 oz but it was easy to fill and work with under the car. Hoping it would only take a few ounces I went to work. 7 times sliding out from under the car to refill the syringe and the fill hole was finally leaking oil. What the heck! Manually put the car in neutral and ran it for 7 minutes. Went back under the car and it took almost 6 more syringes until it started leaking oil again! 25oz to 26oz low. It makes me wonder if I did something wrong but I followed the directions to a T. At least the transmission should be ready for the drive to Shelbyfest. Next up is checking the alignment to make sure my toe is not excessive.
