This is a super cheap mod. You'll need to order these:
They're a little chunkier than the OEM bulbs so you might need a small rat tail file to enlarge the bulb opening. Or you can pull the diffusers off - that seemed risky to me. The upper console is held on with a clip on each side. Use a plastic pry tool then unplug the wires.
The difference is astounding. These same bulbs fit the license plate lights in my Raptor and made a huge difference there, too.
