1 - 18 of 18 Posts
From Facebook:
2020 GT500 Twister Orange
I saw that wing on their website the other day but I now see they are located about 10 minutes from me, I will stop by there sometime and check it out.
Let us know how it goes Dustin. If I was going to add one to a base model car, I’d probably just get a different trunk lid to paint and add proper holes. Since you are stripe delete, you wouldn’t have to worry about getting matching stripes.
Agreed, if I do it I will get a second trunk lid and do it right so it can always go back to stock without extra holes in things.
Common, Tim. You gotta stop tempting me with this stuff! :ROFLMAO:
Funny Jason!
Think of it as me helping you “save money.” The Ford wing is crazy pricey. This option is much more economical. 😬😆
Reactions: CollectedDust
The Wing is 3000$ 😖🤓🧐😎 on their site. I’m curious how much Ford will want. Thanks Tim
Discussion Starter #11
You’re correct. I bought the one my new order but I’ll get this one someday. I may look for a track pack car. Is Ford going to make the GT500 in 2021 ?
The S550 GT500 is slated to be a three year run: 2020/2021/2022. It’s possible the CFTP markups come down for 2021... we shall see.
Discussion Starter #14
I saw a track pack running taller GT4 spoiler arms (risers). Anyone know where to get a pair?
Was it the OEM wing with taller mounts or and entire aftermarket setup? I believe Ford sells the entire GT4 wing.
Does anyone know if the hatch on a winged/cftp car is reinforced more than a wingless car. Also is suspension set up differently ie spring rates/shocks on a winged VS non wing GT 500?
Discussion Starter #17
I recall a discussion that the trunk lids have different part numbers, but I never saw any evidence to back that up.
The CFTP cars have stiffer springs that are a 1/2” lower. The rear sway bar is thicker/stiffer and there is different programming for the magneride, probably to accommodate the lighter/stiffer wheels.
MPR Carbon in Las Vegas were reportedly making some, contact them.
The FFperformace looks like it is made in China and has the winglets screwed from the outside and has light looking brackets and feeble attachments to the actual wing body. I imagine the wing could collapse due to the high down force in my opinion. Also possible quality issues?
China site by resellers. Some pics are similar if not the same item.
https://www.aliexpress.com/item/100...expid=bb08c594-dbcb-4f19-862e-7a5c4d74f869-37
https://www.alibaba.com/product-det...700.pc_countrysearch.main07.45.9d8452ccqjUytz
1 - 18 of 18 Posts
