1 - 4 of 4 Posts
Have to remove both window scoops. bottom is become unattached. The body shop that painted them installed them. Whats the best way to remove the part thats still attached.
Hair drier, Dental floss, or fine wire. I already purchased new 2 sided tape. The old tape i believe is contaminated because it won't stick anymore.
thanks
LLoyd
Discussion Starter #2
I used hair drier heat and wood wedges. The kind you shim window with. Floss only broke, i was afraid wire would scratch something. Hair drier in the scoop. strart in one corner and start pushing the wood wedge in a little at a time and it soon poops off just don't force it.
i think if it loosens up again i'm going to reduce the flange on the scoop. It appears to be bigger than the opening for the window. I believe it would fit better if were a little smaller. I was going to make a cardboard insert that fits inside the opening for the window. place the cardboard on the scoop and grind away anything outside the cardboard from the flange. Then reattach it.
LLoyd
I used 4lb fishing line to remove my emblems that had 3m tape.
fishing line there ya go. Didn't think of that one.
Thanks Joe.
Lloyd
1 - 4 of 4 Posts
