Ok, being new to the GT500 specifically, and supercharged cars in general, I have some questions and I was hoping some of you guys that have been around this car and modded them can school me here.
My questions relate to available boost pressure vs. gear selection and also, in a related area, what mechanical means (if any) are used to limit boost? I've had a couple turbo cars and boost was regulated by vacuum controlled blow-off valves and I was wondering if/how Ford accomplishes the same/similar function on our engines?
The reason I ask is this. While I realize it's purely anecdotal and not a "reliable" measurement, I've noticed that apparantly in first gear, the engine seems to be limited to ~5-6psi of boost according, at least, to the in dash boost gauge. Now, that said, as soon as I shift to second (or higher) and get into it, the boost gauge will climb to an indicated ~10psi of boost.
So, I guess what I'm asking is, simply, does the ECU limit us to something less than "full boost" in first gear? I can understand this would make sense due to traction issues. And, if so, what method does the supercharger use to limit boost. I know that pulley size mechanically regulates the absolute upper limit of boost the SC can produce by controlling how fast it can spin, but there must be some secondary mechanism for boost regulation that's controlled by the ECU, isn't there?
Sorry for what are probably elementary questions. I hesitated to ask for fear of being taunted relentlessly now and forever more. lol Yet, asking I am. Have mercy on me.
Regards.
Regards.
