1 - 1 of 1 Posts
Vendor
No matter how sleek and fast your Ford Mustang is, and what expensive upgrades you add to it, but you can’t expect it to deliver maximum performance on the road without a set of proper tires. Performance tires will provide excellent grip, precise steering response, and shorter braking distance. We've narrowed down 6 performance tire options popular among our customers to make your shopping easier. Hopefully, it will help you to make up your mind and get the most out of your driving!
#1 Toyo Proxes 4 Plus
Features:
  • Outside Tread: Wide Ribs and Closed Shoulder - increased contact area improves vehicle’s responsiveness and cornering performance
  • Inside Tread: Wide Grooves and High Sipe Density
  • High-Grip Silica Tread Compound
  • New Advanced Tread Compounding
#2 Toyo Tires Proxes
Features:
  • Awesome drag radial tread compound
  • Drag-Race Construction With Special Drag-Race Radial Carcass
  • Two distinct tread areas are optimized for track and street use
  • Variable Pitch Outer Area reduces pattern noise while on the street
#3 Toyo Proxes T1R
Features:
  • Silica-reinforced, high-grip tread compound
  • Refined unidirectional tread design
  • V-shaped main grooves
  • Rigid shoulder rib-bands
  • Parallel shoulder slits
#4 Toyo Proxes R888
Features:
  • Unidirectional V-shaped tread design
  • Enhanced R-compound tread
  • Stiff bead construction and wider tread width
  • Continuous center contact
#5 Toyo R888R
Features:
  • High Grip Race Compound reaches optimal operating temperature quickly and provides consistent performance
  • Large tread blocks on the outside tread maximize lateral grip for improved cornering
  • Wide Center Rib improves directional stability and precise steering response
#6 Toyo RR Tires
Features:
  • Designed for increased grip and improved lap times
  • Provide excellent steering response and feedback
  • Strategically placed around the tire to provide easy tread depth measurement from any position
  • Allows for easy labeling on the sidewall
Toyo Tires Comparison with similar tires:
1 - 1 of 1 Posts
