Your front end isn't heavy enough already?Since we're going to put 315/30's in the back we thought that maybe the rear tires will fit in the front, anybody has any experience on this?
They should fit at stock ride height but I would think the scrub radius on something that wide would be horrible unless you want to crank the camber up which really eliminates the benefit of the wider footprint until you push it really really hard in a corner and is going to kill tire life...No, i want it heavier :thefinger:
I think that the wider tires would help somewhat in handling and since both front and rear wheels measure 18 x 9.5 i think i should ask because i believe they should fit
Thanks for the welcome and sorry for the fingerGee, a little quick on the draw with the "finger" there for a 4-post noob.
Welcome.
And they put those stock sizes on all four corners for a reason. Unless you're racing, they'll suffice. The type/brand/quality of the stock tires, however, suck.
Kids..........."Gee, a little quick on the draw with the "finger" there for a 4-post noob. "
:rofl:
BJ,
your killin me....
Thanks for the welcome and sorry for the fingerthe car is receiving some 315/30 M/T ET Street, what size/brand would be a nice match for the front?
I'll be getting some BFG's when these junk F1's go (maybe before). What size are you guys running on the rear? I want to stay as close to stock as possible.Just a couple of notes:
First, unless you just want these tires for stoplight launches, don't get the 30's. You don't have enough sidewall to have any flex, thus resulting in less hook. Get the 40s if you have to (I know, they're 28" but it's not that big of a deal....plus, if you do 3.73s it'll bring your effective ratio down to about 3.55 and that'll keep you up over 120 through the traps).
I assume you're not putting the 315s on stock wheels. If you are, rethink it. They'll bead OK but the tread will be bowed at street pressures and you'll wear the middle out very quickly. Follow their recommendations for wheel width...you'll be glad you did.
Finally, the stock F1s are crap. Lots of us have used BFG KDWs. They're sticky (for a street tire) and have a ton more rubber for each sq cm of contact patch simply because of the tread design.
Oh....and seriously, don't jack with widths in the front.
